Ivylog
Nov 29, 2019Explorer III
Last summer I went from 95° in Moab to 50° in Colorado and NO I didn’t change my tire pressures. I would not worry about 5 psi one way or another. I would temp the tires and would not have them above 140 degrees in the bottom on the tread...hottest spot. I might go with the next size larger tires when it’s time to replace the current ones so you can run less pressure in them.
38,771 PostsLatest Activity: Apr 15, 2026
