Mr_Mark1
Oct 23, 2015Explorer
PCarnathan wrote:
Mr. Mark wrote, in part: "Luckily, we have a built-in engine fire suppression system with a warning indicator alarm at the driver area along with the 'button' to activate."
I'd like to know a little more about that system if you're willing to share. Thanks in advance.
Pat in Menifee, CA
www.patcarnathan.com
The built-in unit is called a 'Kidde Duel Spectrum' I have a green indicator light that tells me that the system is operating correctly. If there is a problem, the alarm will sound and then I can activate the 'button'.
It is noted in the manual that the coach will need servicing if that system is activated to have the engine cleaned, etc. (if a false alarm or minor issue).
MM.
