10forty2 wrote:
Don Don wrote:
If you blew the same tire you have other issues.
It was not the same tire...same wheel. Inner tire blew last time. Outer this time. Old tire last time. Brand new tire this time.
Wait... if they took an old tire and moved it from the outside position to the inside position (since your NEW tire blew on the outside), I would hope that they made sure that your tires DO NOT have a directional pattern. I know that mine do. There is an arrow on the tire near the rim to show which direction they should be rotating when going forward.
To mount a tire from the outside position to the inside requires flipping the rim around, so your tire which was rotating counter-clockwise when going forward is now rotating clockwise going forward, unless they unmounted and re-mounted that one too (which I doubt).
