tinkerer's avatar
tinkerer
Another debate or opinions
On my Discovery coach about 4 years ago I made a habit of starting it driving it for about 10 miles, cycling the slides,the trouble some electric jacks, and the generator every other 30 days. The slides work so much smoother, it ended my electric jack problem. My opinion is it not good for a motorhome to just sit for months without use. One poster pointed this out when I post my last post about the C7 fan pulley bearing. By they way we are parked in Arizona for 3 months and I still start it up and cycle everything but don't drive it. Before I did this the brakes had a tendency to hang up a little bit after sitting for 3 months. This ended that problem. Just interested in opinions on this subject;)
  • All of that exercising is fine but occasionally stuff will still break. No amount of exercising, or travel use for that matter, will prevent the inevitable failure of some mechanical parts. The problem is that you just can't predict when a part will fail. Preventive maintenance helps but, as many have found out, sometimes the replacement parts are not as good as the original.
  • Ivylog's avatar
    Ivylog
    Explorer III
    I have diesel powered heavy equipment that often sit for a year+ and put fresh batteries in and they start right up... one dozer is only 45 years old. I agree tires last longer if exercised. The three months snowbirding is usually the longest my DP sits and on the day before I plan to leave I crank it up for the first time and let the coach air up. There is lots of farm equipment that sit for 4-5 months in the winter... many 40+ years old.
    I have a portable welder that sits outside, often so long between uses that the magnetism collapses and it will not weld. Spark the leads to a 12V battery and it's good to go. It was probably 20 years old when I bought it 40 years ago. Do you think I exercise my generator every 30 days?
    I guess if you have nothing better to do, then taking your rig out for a 20 mile trip running the generator is not going to hurt anything, but just cranking them up will. Different strokes for different folks.
  • The one change I would encourage would be to drive it a bit further each month. Your objective is to get the transmission up to normal operating temperature. If a 10 minute drive achieves such then disregard. I'm fortunate enough to have the coach in the driveway and the interstate 5 miles away. Drive a couple of exits turn around and come home. Run the generator at the same time to keep it happy.
  • This also applies to motorhomes.......use it or lose it.
  • My grandfather used to say "If you dont use it you lose it". Yes, I could tell you some stories about that guy. :)
