rgatijnet1
Jun 01, 2014Explorer III
If you look at weather underground or many other weather sites, they will tell you the ozone levels in your area. Ozone is one of the main things that causes the rubber on your tires, and other products to degrade. Higher ozone levels means your tires will start to degrade sooner than if you are in an area with lower ozone levels. The tire manufacturers pick an AVERAGE that is based on experience.
Tires that are exercised daily will last longer than tires that sit for months on end exposed to the elements. Excessive mileage and a worn tread is way down on the list of why RV tires fail.
38,782 PostsLatest Activity: Sep 21, 2026
