rgatijnet1
Jun 17, 2015Explorer III
Any electronic or electrical device can work and then stop working. That is the nature of most things that fail. Perhaps there was moisture/high humidity where you stored the vehicle, or it just could be bad luck.
Did they check the generator for the CORRECT voltage output? If it is too low or too high, your EMS may prevent the power from getting to your main electrical panel and the power you are seeing at the TV's is just power from your inverter. .
