craz z wrote:
I don't know if this applies or not. with the solar you have all power functions still running of inventor making you think power is restored with the sub panel breaker. with exception of AC.
I'd suspect you flipped the genny breaker. go to the genny and pull the panel off there is a master breaker that probably tripped. happened to me once all was well again.
Did u start the genny with the ac on? there is a high load and it makes it difficult to start could have tripped the breaker as well.
No I usually let the generator run for a few minutes before I start the A/C unit.
I did reset the circuit breaker on the generator. Right now I am dealing with other problems that are more important (Family health matters.) than the Generator.
Thank you for the replies. I will deal with it when I have the time.
