LongWeekends
Feb 09, 2016Explorer
ncrowley wrote:
It will get worse. I purchased a coach with paint checking and thought if I kept it under cover, it would not get worse. I was wrong. Within 2 years, the checking in the dark spots (where the worst checking was) got so bad that it lifted off the clear coat in a number of areas. At that point, you have a problem. And I kept the coach totally out of the sun whenever I was not using it. If it is in the sun, I assume it get worse more quickly, but no matter what you do, it will get worse.
Thank you, that is the info I was looking for.
