zert800's avatar
zert800
Another problem
I replaced the coach batteries a month ago and that fixed all my issues I was having, now here is my new problem, the fridge isn't working, I am plugged into shore power, everything is working but the fridge, all the lights flash on it flash and there is a clicking. The fridge does work when switched to gas. the batteries are charged.
Thanks,
Frustrated.
  • zert800 wrote:
    Old-Biscuit wrote:
    Thanks,
    Frustrated.
    Worked OK when you replaced batteries couple months ago.
    Now not working on 120V AC BUT does work OK on propane
    Panel lights flash and clicking noise
    Sounds like AC relay stuck on circuit board
    What Brand/Model Fridge?????????
    It says Dometic Classic. It has been turned off now for two days, I unplugged it and turned it on, it started up on gas and was working fine, I then plugged it back in and it is working now on ac and seems to be fine. So far.
    Your earlier post seemed to about a 'current' problem
    Now this post is stating it works OK
    So what was reason for post?
  • Old-Biscuit wrote:
    Thanks,
    Frustrated.
  • Toddupton wrote:
    Does the outlet have power to the fridge?
    X2 It sounds like a 120v ac problem.
  • mike brez wrote:
    Is the clicking the ignightor trying to lite the fridge? Do you have gas to your stove? Did you try to reset the LP detector?
    Dude, did you read the post?
  • we did the same thing. The refrigerator had to be RESET. Not sure how that was accomplished as we had taken it to repair shop because we thought it was broke. You might try calling the help desk at frig manufacturer and they could prob tell you how to do it. Sorry I am unable to tell you how. I should have asked the repair man what he did, but did not think of it at the time.
    Thanks,
    Frustrated.
  • Is the clicking the ignightor trying to lite the fridge? Do you have gas to your stove? Did you try to reset the LP detector?
