Dutch_12078
Feb 27, 2016Explorer III
VCBandit wrote:
The Norcold is a model 8421M. It is 591/2"H X 231/2" W X 23" D. One of the other posters suggested a Haier. I found one that might work so will check it out. We have a 2000W PSW inverter, solar and adequate house batteries so should be good in that area.
We replaced our Norcold 821 (same dimensions) with a Haier 10 cu ft that was a near perfect fit in the opening. A bit of prefinished trim around the edges finished it off nicely. This link is to a post I made last fall showing the modified window latches I installed to keep the doors secured while under way. I used the original Norcold rear bracket to secure the Haier to the floor.
38,769 PostsLatest Activity: Mar 30, 2026
