Dutch_12078
Mar 01, 2016Explorer III
booty51 wrote:
I have a question . When the old fridge is replaced with residentual. What is done to the large vent panel and the large hole that is now facing the back of the fridge. Also what is done with the roof vent. I can see the new fridge cooling fan blowing out the vent on top. What kind of wind noise do you here when driving after the modification.Also what about rain?
There is much less heat at the back of a residential fridge, so the existing vents can be at least partly closed off. If the new fridge is sealed tightly into the opening with no circulation space over the top or under the bottom, then the vents should not be completely sealed off. I don't understand your question about noise and rain, since the original vent covers are typically left in place and just closed off inside or underneath where it's not visible from the outside.
38,769 PostsLatest Activity: Mar 29, 2026
