fcooper
Mar 01, 2016Explorer II
booty51 wrote:
I have a question . When the old fridge is replaced with residentual. What is done to the large vent panel and the large hole that is now facing the back of the fridge. Also what is done with the roof vent. I can see the new fridge cooling fan blowing out the vent on top. What kind of wind noise do you here when driving after the modification.Also what about rain?
The small Haier unit I installed has coils on the rear but no cooling fan. Since hot air rises, I get air circulation from below (drilled some holes in board over furnace) and the hot air exits in the small gap above the refrigerator.
I sealed the overhead vent. The side vent I partially sealed with a section of foam board. I wanted access in case I need to remove the bolts holding the refrigerator down, but still wanted to block as much air as possible.
Fred
38,769 PostsLatest Activity: Mar 29, 2026
