Meffrig's avatar
Meffrig
Another surge guard question??
Probably a silly question but.......bought a new 2014 Thor Windsport (50 amp hook up) last October and am wondering if it has a built in surge guard to protect my electrical stuff in my Class A.
I have read the generic owners manual over and over and can't figure it out. From reading other threads in this forum, many of you really believe a surge protector is an absolute necessity for peace of mind when hooking up to a campground pedestal. I guess I could call Thor and find out as well. Any advice would be appreciated.
  • progressive industries is the best. had a little problem with mine and they said it to us. we did and no charge for it. o ring leaked a little causing it to not work. will never be with out it.
  • WoodGlue wrote:
    I don't think any mfg has a built in surge guard. I could be wrong.
    When you do buy a surge guard, I'd go with the Progressive Industries one, because it is great customer service and a lifetime warranty!
    WoodGlue
    Country Coach did have!
  • Newer Tiffin DP have a standard SurgeGuard RV Power Protection Transfer Switch.
    Note: SurgeGuard also makes a RV Transfer Switch without Power Protection. There are several models of Surge Guard so check your individual RV.
    http://trci.net/products/surge-guard-rv/transfer-switches
  • I don't know your abilities or desires for DIY but if you can change out a light switch you could install a Progressive Industries hard wired one.
  • We have a 2014 Hurricane, and there was no surge guard on it, so doubt there is one on yours. Dealer included a 50 amp unit with coach.
  • Don't know how your RV is configured, but wherever the electric cord comes into your camper, it should be behind a panel, somewhere. You should be able to remove this panel and look inside to see how the umbilical cord comes into the camper and is attached to your converter - power supply. Somewhere between the space where the cord comes through the wall from the outside to the power supply converter, you should find a surge protector. If none is there, I suggest you call your dealer and have them look it up and tell you where it is, if one exists. If none exists, you can install a permanent one inside your coach, get one that attaches outside the coach on the electric pole-plug. Somewhere inside the coach, you should have a panel you can remove so you can see where the cord is.
  • I don't think any mfg has a built in surge guard. I could be wrong.
    WoodGlue
  • One of these saved my coach twice during a storm in southern Arizona a couple of years ago. I'll never leave home without it.
