rgatijnet1 wrote:
RLS7201 wrote:
I suspect not many here have had the opportunity of mounting and balancing tires. Some of the tire build quality can be judged by out of roundness, side to side run out and the amount of weight required to balance the tire. Ask any good independent tire shop what they see. It might surprise you.
Richard
Most every tire has paint marks(yellow, red, or white) that indicate how the tire should be mounted and orientated to the valve stem, etc.
Most "tire installers" who mount the tires have no idea what those marks mean.
That's because the valve hole on the wheel isn't consistently a mark for anything. It's usually randomly drilled.
