427435 wrote:
If you want/need a 4WD pickup, buy one that can be towed 4 down. Ford, Chevy, and Dodge 4WD's can be.
Don't assume that it can be towed 4-down just because it is 4wd. It will have to have a neutral switch on the transfer case. I have been looking at Fords and from what I can find out in the F150 you have to get a Lariat or higher to get the neutral position. In the Superdutys Lariat and up don't get the switch.
Also, as others have cautioned, don't believe everything you hear or read about the tow capacity of a coach. I have found a lot of mis-leading statements, even in factory printed materials.
