V10guy's avatar
V10guy
another wax ?
Hi there,
A little confused...see my siggy below for my coach... I bought some Meguiars Ultimate Liquid Wax the other day from Wally world, the most expensive Meguiars there was...was going to do a thorough job on the MH. Is this a good wax for my coach? Will it be ok on decals?
My main concern is protect it. I see when I did searches...that many use Aerospace 303 on the whole coach...Should I just go that route? Seems easiest...
THANKS.
  • mark5w wrote:
    Again 303 will wash off in rain. I prefer to Rejex the whole thing.
    Thanks! Where's the best spot to get rejex?
  • But best read the instructions first for Rejex, as it is not easy to properly apply. -
    "REJEX APPLICATION
    Ideally, RejeX should be applied to a cool, dry, clean surface. When over 85° F, be sure to apply RejeX out of direct sunlight. If the surface is too hot, the coating can cure before it has properly bonded to the surface, so it may not perform up to its potential.
    RejeX is wiped on, allowed to dry to a haze for approximately 20 minutes, wiped off, then allowed to cure for 8-12 hours (depending on the humidity; the higher the humidity, the faster the cure). Curing is required to allow the monomers (polymer building blocks) that make up RejeX to attach to the surface being treated and to crosslink into a crystal-clear, impervious film. It is important to allow RejeX to cure for 8-12 hours after the haze has been wiped off. If the coating is exposed to contaminants such as oil, fuel, soot, hard water, tree sap, cleaners, etc. before it has cured, the contaminants may interfere with or imbed in the protective film."
  • I think I will stick with NuFinish. I can apply in the sun, which there is a lot of in the Nevada desert, and I don't need any humidity for it to cure, which there is not much of. Simply wipe on and then wipe off just like the Karate Kid.:b
