JaysonD
Oct 24, 2016Explorer
Anti-freeze in the heater
Hello everyone. We just got a 1998 Itasca Sundancer DL 29WU and we love it. It's now time to winterize the beast and no matter how hard I try to make this work, I always end up with antifreeze in the water-heater. I think it's only a one valve by-pass system since there is only one valve next to the water heater. I've tried in both position but I still get fluids inside the hot water tank. Has anyone ever had this probleme? I'm in a bit of a pickle because it's suppose to go below freezing point in the next few days.
If I'm stuck, can I ust fill the water heater with anti-freeze and llve with it this winter and get a proper 3 valve bypass system installed in the spring. A case of 4 gallons of RV antifreeze is only 10$ right now
Thanks
JD
Thanks
JD
