time2roll
Feb 07, 2019Nomad
CoeyCoey wrote:What you want is a plug-in hybrid motorhome.
What I want is an EV that can be towed, and then the regenerative braking power goes into the car battery and house batteries. Also, you could use the EV as an extra battery back for electricity when boon docking.
You can tow any EV and it will charge a bit the entire time you are driving. That is until the battery is full. Then EV just coasts. The braking system that applies the brakes would create additional regenerative charging while stopping (most EVs). However NO manufacturer officially allows their EV to be towed 4 down. Best recommendation I have would be to pick up an old LEAF for a few thousand and give it a go.
You can leave the EV 'on' and it will keep the 12v battery charged. You can draw power off the 12v EV battery either direct, use an inverter to drive maybe a 20 amp charger, or use a DC-DC charge booster to feed the MH house battery.
38,766 PostsLatest Activity: Jan 10, 2026
