steved28
Feb 08, 2019Explorer
westernrvparkowner wrote:CoeyCoey wrote:The only flaw in your plan is that pesky law of physics known as the law of conservation of energy. Simply put, energy cannot be created. The energy you would put into the batteries would come from increased loads on the tow vehicle. Any savings in costs of recharging from a traditional plug connection would be more than offset by decreased fuel economy in the motorhome.
What I want is an EV that can be towed, and then the regenerative braking power goes into the car battery and house batteries. Also, you could use the EV as an extra battery back for electricity when boon docking.
With one exception. The idea behind regen braking is to use energy that would be otherwise turned into heat in the pads etc. So if the toad has a braking system, and you utilized the regen braking only when you are actually braking, then you could recover energy that would have otherwise been used to heat the pads.
