wa8yxm
Mar 03, 2021Explorer III
Though I have heard of tank to tank transfers they are "Discouraged"
A much better solution is called the "Extend-a-stay" This is actually a brand name of a product once made by a company (Marshall brass) my mother once did a consult for.. but alas I do not think they make it any more.. MOST RV stores if you ask for it they will take you to one of several competing nearly identical products. }
The full kit consists of a 4-way manifold that goes between the tank and the regulator. This manifold has 4 ports. The main inlet port is a POL fitting to match your RV's tank, the main outlet is either an ACME or POL to match the fitting on the regulator. The other ports are a "Quick Connect" (like the top of a disposable bottle) and an "inlet) small nut or bolt (Plug really) screwed into it .
Plus two hoses
one is a 10 foot Quick male/female for running a portable grill off the RV tank
The other is a short (5') hose Acme to that secondary inlet (the one with the plug)
Check valves insure propane only flows out the outlets and other valves only when a hose is connected to the aux-out (Same as the bottle it resembles, same kind of valve)
Had one on my Rig for 15 years used both of the Aux ports at one time or another.
Plus two hoses
38,782 PostsLatest Activity: Aug 30, 2026
