wanderingaimles
Mar 03, 2021Explorer
MountainAir05 wrote:wanderingaimlessly wrote:
I'm not a specialist on this, but a question, Since many people run a portable grill from a low pressure line run from the RV system, Why , couldn't you attach a tank with a grill regulator to one of those fittings to basically back feed the system after turning off your main tank?
vapor and liquid.
No, I said "after turning off your main tank"
At that point you are not attempting to fill the tank with liquid, you are supplying a vapor to the system, the same as happens when running from the main RV tank, just flowing from a different source and direction.
38,782 PostsLatest Activity: Aug 30, 2026
