time2roll
Mar 03, 2021Nomad
theoldwizard1 wrote:To move liquid you would need to cool the tank to maybe -45 degrees maybe a little lower. OK it would move as a gas and condense into liquid in the very chilled tank.
The pressure in your tank varies with temperature. If you want to transfer the LP, you need different pressures. Cool the receiving tank in an ice water bath. If not practical, heat the full tank with hot water.
Dry ice at -78F would do the trick.
38,782 PostsLatest Activity: Aug 30, 2026
