theoldwizard1
Mar 03, 2021Explorer II
time2roll wrote:theoldwizard1 wrote:To move liquid you would need to cool the tank to maybe -45 degrees maybe a little lower. OK it would move as a gas and condense into liquid in the very chilled tank.
The pressure in your tank varies with temperature. If you want to transfer the LP, you need different pressures. Cool the receiving tank in an ice water bath. If not practical, heat the full tank with hot water.
Dry ice at -78F would do the trick.
Yes, I was not clear ! I was referring to a "gas only" transfer.
Works great for combining two 20lb BBQ tanks into one !
38,782 PostsLatest Activity: Aug 30, 2026
