jesien24's avatar
jesien24
Any suggestions on where to find a spare rim for Class A
We have a 1999 Coachmen Santara Class A. Looking for a spare rim( did not come with one) it is a f53 chasis. Need it to be a 19.5 8 lug. Called dealer where we purchased it from and they said they couldnt help us locate one. Need one for spring. Any suggestions?
Thank you in advance,
Sandy
  • AZAmmochief wrote:
    These are unique, but I found one at a road side tire store in Toltec AZ. I needed one for a mounted spare. Check on line as well, but make sure you have the right part number. I also checked with the Ford truck dealer as well. Mine was about $260.
    They are the same rim as used on every cab and chassis F-450/F-550 made from 1998 to present! If that truck has 19.5" rims and 8 lugs, it will also be the same size, and have a required minimum weight rating. The 4X4 F-450 pickup is actually a dressed up F-350, and come with 18" rims, so it will not work.
    If you have a 22,000 and above GVWR, then the Ford dealership can get a new rim, but used ones might be more difficult to locate.
    Any RV junkyard can normally locate a part for you, as most are computer listed parts, and will be able to check other nearby junkyards for a used rim.
    I have a 97, and the only 19.5" rims for my motorhome are from aftermarket places, (I have 10 lugs and factory rated rims at only 3,050 pounds at 90 PSI. Your rims have a much higher weight rating).
    RicksonTruck.com
    Good luck!
    Fred.
  • Yes from Pa. just went on their site and sent them an email. Thank you
  • Husband works for a tire store and they cant.. will try salvage yard.. 3 different places said it has been discontinued and ford dealer
  • These are unique, but I found one at a road side tire store in Toltec AZ. I needed one for a mounted spare. Check on line as well, but make sure you have the right part number. I also checked with the Ford truck dealer as well. Mine was about $260.
  • Go to a heavy duty truck/trailer wheel place. I am sure if they do not have it, they can order one.
