fcooper
Jun 05, 2015Explorer II
Bucky wrote:
Most of the bottom of this rig is flat with no access to the frame. All of that is in the basement. I snuck the brake controller wire into the basement in the front and out of the basement toward the rear of the basement.
Sounds like you don't have many options. I think you could (1) use the same method as the brake controller wire or (2) install some type of rigid wire conduit along the flat bottom of the rig.
When I installed rear cameras, I could run the wire along the frame rail/existing wire looms. It sounds like you do not have that option available.
Let us know how you solve the problem.
Fred
38,763 PostsLatest Activity: Dec 05, 2025
