DSDP_Don
Feb 18, 2014Explorer
Some of the systems were affected by the outdoor shower. Often people would turn on both valves on the outdoor shower and then shut the water off at the shower head, leaving the water on and causing a hot/cold mixing issue.
We got a new coach with an Oasis hydronic unit. We had some issues with cold showers the first couple of nights. I called Oasis and learned some things. First, the unit had a valve that could be opened allowing more hot water through the system. The tech also stated that if the campground water you're using is really cold, it can cause an issue. They recommended using the tank water with your pump and then refill the tank.
Lastly, we all want great water flow/pressure, but if you have too much flow, the water heater doesn't have a chance to heat the water.
38,769 PostsLatest Activity: Mar 31, 2026
