Desert_Captain
Oct 23, 2015Explorer III
pnichols wrote:
Ron, I'm curious. What parameter reading from your Scanguage II do you pay most attention to?
I recently had to replace my 2005 E450 V10's Torqshift transmission after only about 51K miles on our Class C. Several mechanics said that this particular transmission failing this soon was HIGHLY UNUSUAL and, upon tear-down analysis, found that several components inside the original transmission were shot.
I wonder if pulling long uphill grades at 55-60 MPH, at 4000-4500 RPM, in the mountains, in the summer, with our only 11,800 lb. motorhome could have caused my early transmission failure? I had no way of monitoring tranmission temperatures while doing this. The transmission fluid in the failed transmission was normal color and at normal level before the transmission shop replaced it with a 3 year unlimited mileage remanufactured transmission.
By the way, my BIL's 2015 loaded pickup truck includes readouts on the dash of all kinds of vehicle performance parameters. I wonder if this is going to become common in new vehicles such that Scanguages will eventually no longer be required in newer RVs?
Phil, this is why I preach the gospel of "Scan Gauge" so often. Being able to monitor your trans fluid temps is essential. You would be amazed what even a slight grade over a few miles will do to your trans temps if you are not in Tow Haul (or have OD locked out on the older models).
I'm not saying you cooked your trans but I am sure there have been times when it was way hotter than it needed/had to be simply because you were not aware the temps had risen so much. A total failure at just 51,000 miles is strange to say the least. I think the Scan Gauge is up to about $150 on Amazon and would, IMHO, be money well spent.
I always monitor trans fluid and coolant temps along with average and real time mpg on our Scan Gauge. There are a couple of dozen other displays available but those are the four that give me the best info. In addition to SC's many other attributes don't forget they are a built in code reader.
Works for me.
:C
38,766 PostsLatest Activity: Jan 10, 2026
