Dale_Traveling
Oct 07, 2015Explorer II
Tinstar wrote:The temps look OK and I would not expect the front to back temps to be the same as you would expect with a car. Front to rear axle weight distribution has a dramatic effect. As long as the left to right temps for an axle are consistent you should be good to go.
,,, front measured almost 160 degrees but the back were 280 degrees ,,,
Concerning replacing the brake lines, rather than replacing the hard lines replace the flex lines at each front wheel and the one line for the rear axle first. Internal corrosion could occur but it's pretty rare while flex line internal collapses is a bit more common.
