Tinstar's avatar
Tinstar
Anyone check the temperature of their brakes
Are there any of you that have checked the temperature of your disk brakes after 30 or 45 minutes of heavy use. Are the front and rear disk about the same temperature and what temperature were they?
  • I have a problems with my brakes sticking. I smelled burnt brakes one day so I started checking the temps with a laser thermometer. Normal use they see about 150 degrees. When they get stuck I see 300+ degrees. The front pair are the ones sticking which are brand new USA dexter hubs that the previous owner installed. I know they are stuck because when I'm on a downgrade hill and hit the brakes and then release, the truck stays still. If I reverse a couple feet then they unlock and roll foreward. Sorry to hijack the thread just posting in case someone may know what's going on.
  • I have seem mine red hot once, what I believe is close to 2000F.
    Not that I wanted to touch them to check.
    Had my lesson in underestimating the grade.
    In most situations it is front that slows mostly and those brakes always get hotter.
