JRscooby
Oct 12, 2021Explorer II
I have never read the manual on any electronic engine except 3406-E, and don't remember what it says.
My fix has always been pull and fill the filters with clean fuel. Disconnect input line from filter, blow in tank until fuel comes out line. If the 2nd filter was real low, I take the input to it and repeat. Work my way up the system, bleeding air, until I get to injector or to the point where leaked fuel would get in the oil. Then I crank it.
If the primary pump is in the tank, and you can make it run you would not need the air. But a pump is often lubed by the fuel. If run dry might damage it.
38,782 PostsLatest Activity: Sep 01, 2026
