fulltimin
Apr 19, 2020Nomad
I had to add a little glue between the original plywood and the cedar boards, at the top end of the door. Evidently, I didn't have enough glue up there, and about an inch or two up top, did not glue together.
Here you can see the glue line and the extra glue dripping at the top edge.
It's always best when clamping wood, to add an extra wood block between the clamp and the wood, to avoid putting a dent in the wood from the clamp.
Here you can see that I have wood on both top and bottom of both sides of the plywood.
38,771 PostsLatest Activity: Apr 21, 2026
