fulltimin
Apr 30, 2020Nomad
Old Islander wrote:
Sounds like good stuff...! Is it the kind of hot-roofing that is typically installed on a flat roof with a tiger-torch? How will you attach it to your RV roof?
This is usually used on a flat(ish) roof with an adhesive applied, and immediately rolled with a roller to insure proper adhesion.
If splicing pieces together, they are usually heat welded at the seams with about 800 plus degrees of heat with a roller to help make sure there is a proper seal between the 2.
Overall, it looks like it should be a good, durable, long lasting roofing material.
Since my roof is less than 9' wide, I won't have to seam anything, with the roll being 10' wide.
I'll have to double check, but I think the adhesive is somewhat over $100 for a 5 gal bucket. That should be plenty to glue that to the plywood.
I'll have to wait for a time when we've got a few days of good dry non windy weather for that.
38,771 PostsLatest Activity: Apr 15, 2026
