Bruce_Brown
May 19, 2020Moderator
fulltimin wrote:Brob wrote:
Do you have a plan on when you may have the opportunity to permanently install the TPO roof?
Any more thoughts on using it for the siding?
Sorry, I didn't see your post last night. I went to bed early.
As far as gluing it down, I need to figure out how to get up to the correct height, so I can apply the glue, and still be able to manipulate the TPO without putting air bubbles in it. My truck bed is about 3' off the ground, but I still need some additional height, and trying to use a ladder just isn't going to cut it.
Some scaffolding would probably be a great addition, but I'll need it to be 20 feet long, (truck bed is 16'), and I suppose work from one side, and then the other.
I still need to purchase the glue for the TPO.
Why not work from the roof?
I've done (2) roofs recently. Take the material and lay it out over the roof. Once you're satisfied with where it's at roll it up to one end. Next put your glue in a paint tray and roll it on a section at a time, unrolling the TPO on to the glued section as you go. I normally do 4-5 feet at a time. Use a floor squeegee or broom to work any bubbles out as you go. It really isn't a bad job. The first one I did I was thinking I'd need help. When I was ready to do it no one was around so I figured I'd get started. Easy job. When I did the second one I didn't want anyone around.
On the glue, check with your local roofing supply house or RV dealer. When I was looking I found the glue was cheap enough, the freight wasn't. My local RV dealer buys it in buckets - they were happy to sell me a few gallons.
38,770 PostsLatest Activity: Apr 12, 2026
