fulltimin
May 28, 2020Nomad
The second thing I forgot to mention is with this picture.
The 1.5" wide black walnut here is shown with the Kreg jig set for 1/2" thick stock. Adding the 3/8" block at the bottom, will work for this setup. If, however, I was using 3/4" thick stock, and had the jig set for 3/4" thickness, and 1.5" wide stock, this setup would not work.
The piece of the Kreg jig with the holes would be higher than it is now for the 3/4" stock, so adding 3/8" to the bottom would still not work for that setup. Hope that makes sense.
38,769 PostsLatest Activity: Jul 09, 2020
