fulltimin
Jun 22, 2020Nomad
You know, as rv'ers, we deal with the gray and black water tanks and their contents, from time to time, and hopefully all goes well during the dumping of the tanks.
Should something goes "haywire" during the process, it can make for some interesting amusement, at a much later time, after the trauma has worn off, and it becomes "funny".
When I was driving the rollback hauling cars and people around, that had broken down, (yes, the car, not the person broke down), I used to tell them, "Someday, you will look back on this experience, and laugh. Today is not that day".
Such was my experience today.
After an early start this morning, my wife took her early morning shower, at the end of which, she not so calmly informed me, that she was hearing water running in the basement. She also informed me, that there is not supposed to be water running in the basement. (like I didn't know that).
Walking down a flight of steps, I discovered there was no water running in the basement. However, there HAD been water running into the basement, which was obviously, not a good thing.
Standing there looking at the mess before me, I discovered that what was on the floor, was not as I had thought, fresh water. No sir. This had the unmistakable air of being gray or black water.
As you know, gray water can smell as badly, or worse, than black water. As I am looking for "lumps", and fortunately, finding none, I discovered that the end of my wife's shower, was now on the basement floor!
Cr@p. Well, not actually cr@p. It was gray water.
Now if you think, trying to unclog a black or gray water pipe on an rv is a real bear, it turns out, that trying to find and unclog about 30 feet of 4" diameter pipe, for a house is a real "Bear".
Since I am not a professional plumber, I do not have a "wire snake", that they use, which is 50 feet long, and can stretch from the house all the way to the septic tank.
I spend part of my day using a much shorter version of the wire snake, pushing, shoving, rotating said snake, to no avail. Then I started on the opposite end and started trying to unclog things from the outside in, instead of the inside, out.
Fortunately, I finally found the obstruction, and "wire snaked" the cr@p out of it, (pun intended), and water started flowing freely again, like it should have.
So, we are back in "business", (pun intended, again), and can now flush freely, again. Life is good.
Hope your day was a little less eventful than mine was. Just for the record .... after all that excitement in 89 degree, full sunshine weather, with a real feel of 100 degrees .... NO, I never made it to the motor home to work.
38,769 PostsLatest Activity: Jun 25, 2013
