fulltimin
Jul 01, 2020Nomad
Fiiiiiiiinally managed to get some work done today. Wahoo!
I cut my black walnut counter top pieces to the correct size. They had been just rough sized before this.
I also drilled some holes in the plywood that the walnut will be glued to. I intend to use 1" screws from the bottom to help fasten the walnut while the adhesive cures.
I plan on covering the entire bottom of the walnut slab with adhesive, like I did when I glued the insulation to the plywood walls and ceiling.
38,769 PostsLatest Activity: Jun 25, 2013
