fulltimin
Jul 13, 2020Nomad
Larry202br wrote:fulltimin wrote:
Next up are the pieces of aluminum angle that I wanted to install on the corners of the 2 counters to secure everything together.
First thing I did was to remove some of the plywood on the corner of the wheel well. I took enough off, so the aluminum would be flush with the plywood, after installation.
Did you remove that wood with a chisel? Neat job!
No, I actually used one of these......
It's a cordless Ryobi trim router, that will take 1/4" shank bits. It does a really nice job for smaller items and smaller areas, that would be difficult to get to with a full size router.
Using that router, got me within 1-1/2 inches of the floor.
The last 1-1/2 inches was removed with this. Since I now had a flat reference point, it was fairly easy to guide this the rest of the way, and keep it pretty flat.
38,769 PostsLatest Activity: Jun 25, 2013
