fulltimin
Jul 31, 2020Nomad
STBRetired wrote:
When are you going to install the sink? You've already cut the hole for the stove, so you might as well do the one for the sink too.
Did you put some type of finish or sealer on the wall before you put up the wallpaper? Putting wallpaper on bare wood can make it very hard to ever take off if you want to change it later.
What's next after the kitchen area? The bathroom? The living/sleeping area? When are you going to re-install the black and grey tanks?
I have given the plywood a minimum of 3 coats of brushing lacquer, some with a brush, and some with a roller. Either way, the plywood has a good cover for the wallpaper.
Trying to pull wallpaper off of bare plywood would likely remove the top layer of plywood along with it. That would not be a good thing.
Everything else will be done in 2 weeks! Lol. If you believe that, I also have some ocean front property for sale in Wyoming...
I do not have the sink that I want to use for the kitchen yet, so I am not cutting that hole until I do. I think I will give the sink counter top a couple of coats of Por 15, just to reduce the transmission of humidity into and out of the wood, to prevent splitting.
As far as what's next? Haven't decided yet. Could go either way.
