fulltimin
Nov 22, 2020Nomad
Places like this, with the red arrows.
While I am not 100 percent finished with the roof - I have just a little up front, and across the rear to do, I needed to get the plywood out of the weather before it starts to de-construct itself.
With that in mind, I took the scaffolding down today.
These screws came from holding the railing together, the 2 x 3's used for legs, the corner braces that helped strengthen the railing at the base.
All those - sorta important points - took 'em out.
I will say, it's much easier putting them in than it is taking them out. If the angle of the bit isn't just right, the bit tends to slip out of the square drive.
I would love to see Kreg switch to a Torx head, instead of a square drive system. Then again, how often do you take 'em out, once they're in?
