fulltimin
Dec 12, 2020Nomad
This is the joint that I will be using. This was cut with a 90 degree bit.
The bottom piece will be 3/4" thick and fastened to the wall. The top piece will be the piece of wood that slides back and forth.
The circle shows that there will be space between the top piece of wood, which slides back and forth, and the back wall.
The groove will hold the wood in place while sliding back and forth. This setup will be at the bottom and the top of the sliding cover.
