fulltimin
Mar 19, 2021Nomad
JoeH wrote:fulltimin wrote:
It even comes with instructions - you know - for those that actually read instructions....
... and the instructions appear to be written by a native English speaker and not Chinese run thru a translate app ! It says it only hardens with UV, I suppose that would mean that on wood joints, that only the exposed edges would harden ? What if you just put a blob of the stuff outside, would the suns UV rays cause it to harden ?
That is a very good question. I now have the answer. I took 2 pieces of plywood, put a blob on the glue on it at the seam, and proceeded to set them outside in the sun.
I had intended to leave them there for about 15 minutes, as 1 minute did not harden it.
It was about 40 degrees F outside, and I got side tracked, and it was out there for about 30 minutes.
I went out, and the answer is .......
Drum Roll Please..........
Yes. The adhesive had hardened. Sooooo, putting it in the sun will harden it.
38,780 PostsLatest Activity: Aug 05, 2026
