fulltimin
Mar 19, 2021Nomad
Ok, going back to this pic.....
This cup goes into our "Magic Bullet" blender. After gluing the "ear" back on, we have used it several times and it seems to be holding up pretty well.
I figured if it would fail, it would fail right away, but it did not fail - at least not yet.
I have found that the light has to actually "hit" the adhesive in order for it to cure.
That is to say, if I put some between 2 pieces of 1/8" plywood, there is no way to get the light to the adhesive, and it never hardens.
The UV light will not go through the plywood. If on the other hand, the adhesive is placed at a joint, like the plywood above, then it will harden nicely.
So, faithful followers, it does indeed seem to work based on my limited testing so far.
38,780 PostsLatest Activity: Aug 05, 2026
