fulltimin
Jul 28, 2021Nomad
LouLawrence wrote:
This is one of those cringe worthy moments after showing the wood sink idea to the DW. I wonder how it will ride on those upcoming wooden tires.
navegator wrote:
I would recommend rounding the bottom corners also, square corners are hard to clean.
Look into the west system for doing the fiberglass and epoxy, I used it many times when installing navigation instruments on very expensive yachts.
navegator
Should not be cringe worthy. This "box" is not the sink. This is only the "form" that I am making to glue the sides of the actual sink together. The "sides" of the sink will be glued around, but not to, this form.
These ...............
And these .......
Will be the actual sides of the sink. They should end up being about 1/4 inch thick, with Fiberglass/Epoxy on the inside to water proof things.
I guess I wasn't very clear about it, if you thought the 2x3 box was the actual sink.
Sorry. Hope that clears things up a bit. If not, stay tuned, it will soon become more clear.
38,780 PostsLatest Activity: Aug 05, 2026
