fulltimin
Nov 08, 2021Nomad
I had to do a little bit more sanding on this today. I also found a couple of pieces on the right that needed a little extra glue, that only extended about an inch in from the end.
I glued them in and clamped them for the night.
Before I did that, I took 2 pictures. The first one is after sanding and the wood is dry.
The second one, I took some lacquer thinner and wet a paper towel, then wiped the surface. You can see the drastic difference between wet and dry.
That's why we add finishes. Make it look pretty, and protect it.
38,780 PostsLatest Activity: Aug 05, 2026
