fulltimin
Aug 05, 2022Nomad
I originally used a 2 1/8" hole saw to drill the hole. As such, I cut a piece of mild steel roughly 3 inches long that would fit into the slits in my hole saw.
Then, I cut a taper on both sides, and both ends to allow for some clearance while cutting.
I then drilled a hole in the center of the steel and ran a screw in from the side of the hole saw to hold it in place while using it.
38,780 PostsLatest Activity: Aug 05, 2026
