- I then clamped a number of strips together temporarily.
Then a small pilot hole was drilled on both ends for a screw.
- Now for the nitty gritty on putting this puppy together.
As you can see, I needed a bunch of thin strips for the sink bottom.
What to do?
First off, I cut a number of strips a little longer than what I actually needed, and marked the strip on both ends to the length I wanted.
Next was to mark the line from corner to corner where I needed to cut.
- Yes, it's a sink. This will "tell the water where to go". Lol.
The drain will be in the corner, and the wood strips are all pointing in that direction.
I haven't glued the bottom together yet, and it is not glued to the sides yet either, but, hopefully, that will come shortly.
- Time to put things into perspective. We need to join a couple of things together, in order to make it, make sense.
This is my first mock up, and I am getting close to assembly. Yay!
- Then, lets cut a bunch of tapered strips of thin wood on top of the plywood, like this.
Well, that's a little strange. - Sorry for the delay. I thought I was going to be able to get this posted last night, but, I didn't get far enough.
First off, let's take a piece of plywood and put a bunch of pencil lines on it, like this.
ro_sie wrote:
Thank you for the updates. I had to be away for a few days, took a fall but home now so I can stay current.
You're welcome. I hope to get a little more regular with updates.
Hope you are doing well.
Thanks.navegator wrote:
Check out the West method of fiberglass building, and yes the cloth disappears and you see the wood, looking good. thanks for the update.
navegator
Looking into it. Thanks.donkeydew wrote:
are you going to put grass in it for the easter eggs? that is one fancy easter basket,seriously it looks good
Fake grass would not weigh much. I could really load up an Easter basket, couldn't I? Lol.
Thanks.- ro_sieExplorerThank you for the updates. I had to be away for a few days, took a fall but home now so I can stay current.
38,780 PostsLatest Activity: Aug 05, 2026
