- Hope your weekend is going well. Everybody out spending money on things we don't need..... Ah, yea, no.
Anyhow, anyone remember this?
Yea, that's the pattern I used for the the sides of the sink. I took that apart so I could use the wood. - Happy Thanksgiving Everyone!
- Well, I decided to change my plans just a bit, in the bathroom. After considering my options, I went back to an earlier design where the toilet is at the rear, and the shower area will be next to the kitchen area.
Biggest reason is the height of the ceiling. It is higher towards the front than it is at the back, since the roof is tapered towards the rear a few inches.
That allows me to raise the shower floor a little more towards the front.
sundancer268 wrote:
I love the off beat thoughts and experiments, and hope they continue to get posted.
I am sure there will be a couple more in the future, hopefully useful for someone.
Thanks.LouLawrence wrote:
Wow you do know how to get off track! Glue as a long term waterproof finish material? Why do you insist on reinventing the wheel at every turn? Do you have any actual plans to ever complete this project or are you just posting random thoughts to drag this out as long as possible?
Just looking at options for the future. I figured wood and glue kind of go together, since I have used a bunch of both so far in this project.
I wish I was much farther along than I am. No sense quitting now.navegator wrote:
Remember that some glues brake down with long exposure to water or moisture, that is the difference between regular plywood and marine plywood.
If you are thinking of using it for the sink, "do not!" In the long run you will have a real mess, stick to tne epoxy and the fiberglass, that sink will be ausome and a work of aft.
navegator
Definitely not using that on the sink. I already have what I think will be enough Epoxy for that job. I do need to add a curve at the bottom of the sides of the sink, to make cleaning easier before adding the Epoxy.- sundancer268ExplorerI love the off beat thoughts and experiments, and hope they continue to get posted.
- LouLawrenceExplorer IIWow you do know how to get off track! Glue as a long term waterproof finish material? Why do you insist on reinventing the wheel at every turn? Do you have any actual plans to ever complete this project or are you just posting random thoughts to drag this out as long as possible?
- navegatorExplorerRemember that some glues brake down with long exposure to water or moisture, that is the difference between regular plywood and marine plywood.
navegator - After that dried, I added a second coat over the first one, and then coated most of the rest of the cedar.
In this pic, the area in between the arrows has 2 coats, and the rest has only one.
Like I said, I was surprised how much the grain came through.
Why was I looking at this? A gallon of glue is less than $30.
Not sure I will end up using this, but it might be an option.
38,780 PostsLatest Activity: Aug 05, 2026
