- Lt46Explorer IIAs a casual observer, I can appreciate using scrap wood where possible. But, has your frugalness caused you to lose sight of the application? My thought is marine grade plywood would have been a much better choice considering where it's going to live. The bath is a very wet and humid environment.
- After a bit of patience, and some time, and we end up with "new" plywood that is thicker, and much stronger. Now to assemble a new box.
- Since some of the plywood is longer than others, I also needed to secure the other end.
As you can see, I used a piece of plywood, a clamp, a 2x3, the fence that I use with my portable router, and shelving... to clamp it until it dries.
Sometimes, I just use what's available, and figured this would work. - Throw some spare plywood on top of those pieces, and weight it down with tools, bricks, lacquer, Por15, and a few clamps until it dries.
- Soooooo, I wanted to use 1/2 in thick plywood for the sides. I have some plywood, but the pieces I have, are not large enough to create those pieces.
Not wanting to buy another sheet, which I don't "think" I will need much of, I looked around and found something that will work, but take a little extra work to make it usable.
Yes, it's time to create some plywood. Well, sort of.
I have extra 1/4" thick plywood, and plenty to make these sides, IF I glue a couple of pieces together.
That will make nearly 1/2" thick and I have no qualms about gluing them together. The glue will work just fine.
Drop some glue on one of the pieces.
Then, using a 2" wide foam brush, smooth it all around.
- Next up is to create a new platform for the toilet to sit on, that is a little more substantial than this one is.
PastorCharlie wrote:
fulltimin wrote:
I needed something to hold up the shower floor, so I figured left over wood should work just fine. It turns out, putting 2 of them together is exactly the height that I need for said floor.
Yes, I left a "hole" in the one corner so I can run a water line through there to the kitchen side. That should work just fine.
The next owner, while doing a major bathroom rebuild, will pull his hair out trying to figure why you cut the ends of the 2X4 with rounded ends.
Maybe I should put a note under there for the poor next owner! Lol...- PastorCharlieExplorer
The next owner, while doing a major bathroom rebuild, will pull his hair out trying to figure why you cut the ends of the 2X4 with rounded ends. - Then it was time to add some plywood on top of said base. Yea, it's just a hair out of square. That is what trim is for. Lol.
- I needed something to hold up the shower floor, so I figured left over wood should work just fine. It turns out, putting 2 of them together is exactly the height that I need for said floor.
38,780 PostsLatest Activity: Aug 05, 2026
