- Top view...
One set up, and another folded, leaning against the wall.
- Here is a side pic of the completed sawhorse. You can see I used chain to keep the legs from separating. The legs are currently set at about 17" apart an the bottom, measuring from inside to inside of the legs.
- Today I picked up a replacement router bit. That means that I finished the sawhorses today!
I can hear the cheering in the background! Yay, no more sawhorse pics after tonight. Well, maybe. Lol.
Just a quick side note on the Ryobi portable saw. A 15 degree cut is about maximum to still be able to cut through a 1.5" thick piece of wood.
My saw only has a 5 - 1/2" blade. Some of the newer versions of this saw have a 6 - 1/2" blade, and one has a 7 - 1/4" which should be able to cut through 1.5" lumber at 45 degrees.
ro_sie wrote:
Always happens at the best of worst times.
Lol. Well, at least no serious damage was done. Just a momentary delay, in addition to a bunch of others along the way.
Just part of the process, I guess.- ro_sieExplorerAlways happens at the best of worst times.
- I was working on the sawhorses tonight, and had a slight mishap.
No, I didn't remove any body parts.
I applied a little too much pressure while using the router, and ruined the bit I was using.
Time to go the store tomorrow for another one, so I can finish these puppies.
ro_sie wrote:
Hope you and your wife are doing ok there fulltimin. I have heard that covid can come back in and give you a set back. Hope that hasnt happened to you guys. I can only imagine that everyone is like I am waiting to see future progress on your motor home.
Nope, we are just fine. No relapse. Thanks. Planning on continuing the work.- ro_sieExplorerHope you and your wife are doing ok there fulltimin. I have heard that covid can come back in and give you a set back. Hope that hasnt happened to you guys. I can only imagine that everyone is like I am waiting to see future progress on your motor home.
- When they are folded up, they will look something like this, and reasonably flat when set up to use.
- Here's almost what they will look like when assembled.
Yes, I know the tops are not quite level. I had the bottoms too far apart when I took the pic.
38,768 PostsLatest Activity: Nov 21, 2015
