sundancer268 wrote:
Super Glue to keep them closed?:B
Then keep a heat gun handy to release the glue? Lol.JoeH wrote:
Maybe I missed it, but, what keeps the drawers from sliding open while underway ?
You have not missed it. As of now, there is nothing in place to keep them closed.
I have considered using magnets, or a lock type which is part of the drawer pull/latch.
As you can tell, I haven't made up my mind yet.
Any suggestions?PastorCharlie wrote:
I keep Bondo handy to correct the errors of manufactoring.
I have used that as well. I've also used wood glue mixed with saw dust, epoxy mixed with sawdust, used nothing - especially if it would not be seen. There are all kinds of different adhesives to use, and most will work well.- nohurryExplorer
Oh no! fulltimin would definitely use Por 15. :B - sundancer268ExplorerSuper Glue to keep them closed?:B
- JoeHExplorer IIIMaybe I missed it, but, what keeps the drawers from sliding open while underway ?
- PastorCharlieExplorerI keep Bondo handy to correct the errors of manufactoring.
- Another view of one of the sides. It's kind of "funny" what you might find when cutting into the center of plywood.
Here are a couple of "voids" in the center of the plywood.
Don't know if that's an oops or cost savings. Lol.
- I finished cutting the dovetails in the sides to match the drawer fronts, and then started cutting the dovetails for the slides in the drawer sides.
I indexed everything from the top of the drawer side, so the drawers would all be the same distance from the top of the drawer.
These are the 8" high drawers.
I also cut the 5" high ones.
The slides will be 1/3 of the overall height of the side. 1/3rd at the top, 1/3rd for the slide, and 1/3rd for the bottom of the side.
I figured that would give me maximum strength for the slides.
I still have to finish the 13" drawer sides for the bottom 2 drawers.
As soon as I cut the drawer bottoms for these 4 drawers, they are ready to be glued together. Yay! - Pulled out my "big" router today with the dovetail bit in it. I also set up my higher fence, so I could cut some dovetails and needed the high fence to keep the pieces of plywood properly vertical.
38,768 PostsLatest Activity: Jan 26, 2021
